Hi
I have my turbo apart to fix the dreaded t-pipe (I have a brass solution that I will post soon!)
I also took my air pumps apart to clean them (as I removed them to access the pipes at the back of the engine) and one of the filters is cactus.
I know they don't get used much, but it's really dusty where I live so I'd like to replace them to avoid the pump failing and generating an error.
There's no listing I can find in the parts catalogue, only the whole pump.
I've heard it's the same as a Camaro air pump, probably made by AC Delco???
Can anyone help with a replacement?
Cheers!
DS
Any chance you could post a pic of the filter? I have never seen a replacement for them yet but wondering if a EVAP charcoal canister filter would work.
Sorry about the delay, here's a pic.
post-8847-0-79260800-1372680376_thumb.jp
As you can see the filter has basically fallen apart.
I read somewhere that someone had made a new one out of a lawn mower filter element.
It's certainly very similar material.
But this pump appears to be a relatively common AC Delco unit (It says Made In USA), so there must be a filter out there somewhere.
Cheers
DS
I've not seen a replacement filter of that type, chances are it comes only with a new unit and is not meant to be replaced. Hopefully you can find some foam element that will do the trick.
