86 911-All signals work but driver front, parking light works when headlights on. Changed bulb still not working. Any ideas? Maybe relay/switch? Would really apperciate it.
Edited by kimichi
You are describing a typical grounding issue on older 911's. clean all contacts at the light and the ground to the chassis
With the age of the car (I also have an '86), you may also have a broken or corroded wire typically at the socket end. I would pull the light assembly out carefully and examine all the connections and check for continuity between the socket and power wire as well as the ground.
I will check the ground. I think thats the problem but will pull light assembly also and check connection.
Edited by kimichi
