Just replaced the fuel door actuator in my 08 CS1 and it doesn't work. Does anyone know if it needs to be dealer programmed? Actuator 7.5 amp Fuse Line B, F6 is good and my central door locking system is working fine. The new actuator is not making a sound at all and the small plastic ring that usually falls off is intact. I'm hoping it's not the wiring and just a programming issue. Any ideas?
