Eventually I plan to upgrade to a x73, someday.
In the interim I came across some RoW C4S springs, they say they will lower my car 10mm or so, is there any downside to putting these in? Do I need to change out the shocks/struts as well, if that's the case I'll just wait?
Edited by C4S Surgeon
C4S already comes with the sport suspension so you would only need the springs and a full 4 wheel alignment. The shocks and stabilizers are the same. For a MY03 C4S Coupe with 6 speed - the RoW front springs should be marked pink/blue (whereas your US sport springs should be silver/blue). The RoW rears should be blue/white (whereas your US sport springs should be green/red lilac).
  • Like 1
