First post, so please bear with me.
I have a 1999 C2 with 64k miles, purchased in January (or, as I like to think of it, 6k miles ago).
I've noticed that the pedal effort seems stiff. There is no over-center point or varying degrees of stiffness, just a tough push from top to bottom and a firm push back. To verify this, I went and drove another 1999 at a local dealer that had just replaced the clutch; much easier.
Now I don't expect it to be a limp, easy push; after all, it's not a Neon. :)
But does anyone know why the effort would be so much higher on this car than another of the same model? Any repair suggestions?
As the clutch is hydrolic unless you get lucky that you got air in the system, it's the wearing of the disc. It might also be a faulty slave cylinder.
