The mechanics are having problems isolating this issue. I wonder if anyone knows how to solve this problem?
  1. Start car - no problems
  2. Put it into reverse - no problems
  3. Put it into drive - receive error message "Drive Selector not Engaged"
  4. Car drives fine
  5. After around ten minutes, the message disappears
Apparently, there are no error codes showing when the mechanics view the diagnostics. They said they don't know what's causing the problem, but suggest they could replace the selector, but can't confirm that would solve the problem.
Boxster S 2004
Tiptronic
Edited by blackgrape
Test the range selector switch located on the side of the gearbox, moisture can migrate into the connector/switch and cause issues. It can be easily tested with a DVOM.
