Guys I saw a related post on another board, made me think about my little problem.
I had my B&M adjusted perfectly, I used the Porsche special tool to setup the cables on the stock shifter then carefully marked them and re-installed the B&M. It seemed to make a big difference on daily driving , no more clunking into 1st, just nice smooth and short gear changes. The new cable positions were actually a few threads off the OEM placement as we noted on the initial installation.
Everything seemed great, I took the car to the track a couple of weeks ago and it felt fantastic, nice crisp short gear changes. In fact, I commented how perfect the car now felt with the short shifter. Then on the last afternoon of the DE , 3rd and 4th run sessions were run fairly close together, far less than usual down time. This is a normal occurance at the track as everyone wants to finish up and go home. By the end of the third session I hit a gate upshifting 2-3 and it took a couple of attempts to engage the gear. I thought nothing of it. Then on the last run session, the same thing happened at least twice on 3-2 donwshifts and 2-3 upshifts. The car had to be forced into gear.:(
This is really a PITA on a high speed track out at 7000 rpm!
I guess some adjustment problem???? I don't know. I put the stock shifter back until I can come up with a reliable solution for track use. Again this only happens at the track during "extreme" usage.
Edited by dj996
Either it is adjusted wrong or you need some more time with it to get used to it. I have one in my car and have 15 track days with it and have no shifting problems what so ever.
I'm hoping it's something simple too. It really is a fine shifter.
FWIW I have over 30 track days on my 996, the last 4 with the B&M. I have never had any trouble with the stock shifter, but 2 out of 4 days with the B&M I have run into this gate thing...no pun intended :jump: .
Edited by dj996
