997.1 C2S Water Pump and Coolant Procedure with Pics
Attached is pdf file of a write-up that I just completed which details my recent water pump and coolant procedure. So that you will know what you will be getting if you decide to download the pdf, here is the first part of the introductory chapter and table of contents from the document. "Following the completion of my first water pump and coolant procedure on my 997 I decided to do this write-up so that I could use it the next time I do the job (hopefully not for several years). This write-u
