My CDR-24 with Bose, in 2005 Boxster, gives me static and dropped signals all the time. Driving fast, it often causes the signal to chatter and fluctuate. Otherwise it is mostly static, even on strong local stations.
Is this a CDR-24 problem, or is there an antenna connection I should check? How?
Failing that, what's the best aftermarket solution?
Edited by Jampolis
There are several connections to check starting with the leads at the rear of the unit then I think there is a booster located in the A pillars is memory serves. I had a customer complaint of the issue once and it turned out they installed the wrong windscreen in the vehicle so check that you can see the antenna wire in the glass.
Thanks. I can see the wires in the windscreen, which is original and untouched. Checking the leads is a project I'll try next. Not sure I can deal with the A-pillars.
