When I turn the key, you can hear the doors lock and then about 1 second later you hear them unlock. However, the arlarm is indeed engaged and any attempt to open the door will set it off. How do you fix it?
[TIP] If anyone else has this problem, I discovered a temporary "hack" to lock the doors, though it does requires 2 people:
Have someone on the passenger side ready with their hand on the handle. Turn the key and when it clicks, you both immediately press and hold down the handles. For whatever reason, this stops it from unlocking itself.
  • 2 months later...
If the lock solenoid does not fully extend then the controller will immediately unlock.
Common problem, fix the solenoid or purchase a replacement.
When this occurs check to see that both lock pins on the door top are depressing when locking. If one is not then the plastic ball linkage is likely off the pin and may be causing this. You have to take the door panel off of the one not depressing to inspect it.
