Dear Sir's . Has anyone had a problem with gear selection not engaged showing up on the dash. When this happens the car doesn't start after a few turns of the key it will start but I can't find what is causing the problem. Thanks for your help.
Edited by simon1098
The magnet is more for the tiptronic function, there is a multi function switch located on the gear box which is used for P,R,N,D. Are there any other odd electrical things happening such as radio or heater not coming on? Maybe an ignition switch on it's way out.
I had a similar issue with my Cayenne Turbo and the magnets. Dealer had no idea about it and it was not until I found this advice on this forum that they were able to fix it. Magnets got dislodged.
