I'm going in for the kill and will have a write up following shortly after. I'll be changing the thermostat and I believe the high pressure fuel pump is somewhere in the same area. This is where I need some help. If some one can confirm that the (high pressure) fuel pump is in fact near the front of the engine it would save me some time and trouble. Any assistance would be much appreciated.
the pumps are in fact under the rear seats, you have to lift cutouts in the carpeting to access the covers
The high pressure fuel pump location is dependent on engine type
HPFP V8 (Item 11)
HPFP V6 (Item 16)
DFI engines have an HPFP in the engine bay.
Not the High Pressure that I'm going after. I did find it on the drivers side rear top of the engine and successfully swapped it out last night.Pictures and write up will be coming soon.Now the thermostat on the front :wrench: :help:
HPFP V8 (Item 11)
The exact schematic I got from Porsche. Turn it clockwise twice and you have your location
^^^ Will turning it anti clockwise do the trick as well? :huh:
lol, What ever way you prefer? Counterclock wise, clock wise, whatever just flip it around and that'll give you an idea.
