:welcome:
Please do not post in ALL CAPS - on the Internet that is SHOUTING.
If you car has a six speed transmission then it is likely a bad switch. The switch is mounted on the top of the transmission and literally a 5 minute job to change.
There is a DIY Tutorial article here
As both sides rarely fail at the same time, it is usually either the harness has come loose from the switch, or the switch itself. As Loren's DIY shows, it is a relatively simple project to replace it.
