Having done a search to no avail could someone help me on these faults reported by the Durametric?
997 C2S Coupe 2005. 6 speed manual RHD UK
Codes:-
8004 terminal 50 value below lower limit value
8017 right radiator fan motor value below lower limit value
8042 front luggage compartment unlocking implausible signal (info only)
these all reappear after resetting them so 'appear' to be real, but what do I do about them??
what is a 'fan motor value' volts, impedance, current etc?
Any help gratefully accepted :notworthy:
Jonathan
Edited by jl-c
are they causing any issues? i.e. is your car not cooling properly (radiator) or is the frunk not opening when you pull up on the release button? i've noticed that sometimes the codes (esp the "communications" codes" are kind of benign and dont really cause any issues. (just thought i'd mention since you dont really say that it's causing problems, only that you have the codes.)
8004 CAN Comfort
Possible fault causesCAN Comfort faulty (communication problem with all control units via CAN Comfort).- Short circuit of CAN high line to ground- Short circuit of CAN low line to ground- Short circuit of CAN high line to B+- Short circuit of CAN low line to B+- Noise injection in CAN high line- J Noise injection in CAN low line- Short circuit of CAN high line and CAN low line
8017 Right radiator fan motor
Possible fault causes- Radiator fan motor stuck- Open circuit or short circuit in connecting line- Radiator fan motor faulty- Radiator fan control module faulty- Front control module faulty
8042 Front luggage compartment release
8042 Micro switch in front lid lock
8042 Power supply
You can get this one if the battery has been disconnected or replaced - I would reset it and see if it come back.
Thank you very much for the quick replies. Got under it today and had a look see. Fan stuck as you surmised Loren, the luggage compartment issues caused by a stuck micro switch not always turning the light on. Reset and those faults cleared now. No success on the CAN issues though, still coming up. Any idea where I should start looking? Just to top it off it now says reversing light 1 out, and its not they both work??? Ever done something you regret starting? :huh: :eek: :help:
  • 2 years later...
