Hi all,
I have a weird whine in my 03 996 which makes it sound like a sewing machine. Unfortunately I have only had the car a few weeks.
I have done many searches and heard similar sounds with no conclusive solution. Some says its normal, a couple of others have identified thrust bearing or pilot bearing.
Key points:
- The whine varies with revs
- Occurs when stationary, does not matter if moving or not
- Depressing the clutch makes no difference
- Also occurs with the serpentine belt removed, so not alternator/pulleys (I wish it was that easy!)
- It is not the SAI pump, that makes a different whine (and I have that one, but not bothered!)
This is also a Hartech rebuilt engine around 10k miles ago, also had the clutch done at the same time.
Find the sound with the belt on below (listen to revving):
Find the sound with the belt off (skip the pulley checking part), you will see they sound the same:
Anyone had a similar problem and solved it? Or is it normal and I should not worry about it, because apart from that the engine sounds sweet.
Mine sounds exactly like that. It's 1998 996 with 40k miles on it, and to my knowledge in perfect condition. Also my previous Porsche, a 2001 Boxster S with 60k miles sounded just like that.
I think this whine is distinctive to these engines and completely normal. How does everyone else's engine sound like?
Br,
Kimmo
Edited by Kimple
Its beginning to look like this is 'normal'. I got a look at a 996 at the weekend (hard to turn up to a garage in a 996 looking at 996!) and replies on another forum all suggest its normal. I'm going to look at a few more hopefully.
I can't believe Porsche would sell a car sounding like a sewing machine from new!
Some seem to have the sound on youtube, others not, but I guess this depends on how well the sound is recorded.
Once I know more i will update thread.
