My 1999 C2 has developed a rattle in the left muffler at around 3500 rpm and I think it has a loose baffle because it makes a noise when I knock on it with my hand.
I have been able to locate a used muffler from a wrecked 996 but is has a different part nr 996 111 121 90.
Mine has 996 111 121 56. Would this work?
Thanks very much.
Another option for you is fister d motorsports in northern cal.
http://fdmotorsports.net/
The last time I talked to Darin at an autocross I think it was somewhere around $50 or less for the baffle repair (I have a muffler that has the same problem).
They can cut a small hole in the muffler and then reweld the baffles.
They can also install a bypass pipe for more noise and add a ceramic coat.
