Hi guys...see pic (F.105-20 #21, 22). Anyone had any luck replacing these two? From under the car they are way up in there! I'm currently wrapping up a DIY of all 24 coolant hoses...thanks in advance!
post-21455-0-87413100-1367980352_thumb.j
Two ways, one using a set of special cable clamp pliers:
You can also unbolt the tank from the bulkhead and pull it into the trunk a bit to gain access.
