Immobilizer is under drivers seat. You must change that too.
Donor immob/dme/pill in key must all match.
Wiring harnesses must match (otherwise you need to rewire, but prob better option to get another donor set)...
(green box behind key not so important IIRC)
If all the connectors match, I think you should be OK.. IIRC 2001 and 2002 boxster should be compatible both use DME 7.2.
boxster didn't change DMEs to 7.8 until 2003 (not sure about immobilizer, but I think that should be oK too)
I have a question. I have a 986 from 1997 that does not have M531 (Immobilizer) option code. Does this mean that if I need to replace the DME, I do not need any ipass codes, just swap in a new DME?
Thanks.
