2003 C4S 142,000 KM.
i have one of the fuel lines linked to the top of the fuel tank leaking fuel...
i recieved an estimate for changing the fuel line which is very expensive due to the fact that suspension has to be removed, etc...
the shop is also saying i need to replace the fuel level sender/gauge after installing the fuel line becuase it is almost certain that i goes faulty after being dis-assembled...
is that truely the case? or the same one can be used again?
thanks,
Nehme
It is hard to say if the sender needs to be replaced with out actually seeing the damage, but if everything is working OK I would be a bit suspicious of changing it without a sound reason.
