Recently, serpentine belt failed and broke off a bolt and Pulley. I got lucky, got the bolt out with reverse drill bits. Question: Is the bolt I'm replacing need to be from Porsche. Can I use a common bolt from auto parts store, or only order directly form Porsche? I believe its :Item: HEX-HEAD BOLT 8X60 ( part number 900 378 15901 )
+1 for Loren, plus there's a torque setting for those bolts that can be found in Bentley's. Also I would use blue Locktite on the bolt. I had the tensioner pulley bolt back out on my car and it bent the bolt and destroyed the pulley so proper torque and installation procedures are important. Or you could end up spending a night in Winslow, AZ...
