Hi folks..
My driver side fuel pump seems to have failed and the guy at Sonnen is saying I need to upgrade the whole system and buy 2 new redesigned pumps.
Is this necessary? Can I just replace the failed pump?
Thanks..
You may want to check, but I think there was a fuel pump update/revision on some of these cars, which may be why they are suggesting doing them both at the same time as going back to do the second one later is just going to eventually add to the cost and down time.
My drivers side went bad and I replaced that my self. Not hard but just a pain in the .... Now about a year later the other side went (I had my indie shop do it this time) and they said both are supposed to be replaced at the same time but said it shouldnt cause any issue.
