Kessy Module Fix
Tools needed: T20 Torx driver A few flat blades or knifes Soldering Iron Solder Solder wick or desolder tool Parts Needed: http://www.westfloridacomponents.com 1/4W 0.22 ohm Mini-Melf Resistor Beyschlag MMA0204-50AL0R22J - 6 IRFZ24NS FZ24NS HEXFET Power MOSFET International Rectifier - 2 Step 1: Remove Lower panel under drive side. One screw in the middle Step 2: Locate module closest to the center of the vehicle. Module will be installed SIDEWAYS next to the module that has 4 co
  • 3 years later...
56 minutes ago, PizzaFiend said:
Seems the images are missing...
You can try sending a PM to the author as his original images were on a 3rd party site rather than uploaded here.
