Do you think it could be a communication error between the switch and the rear control unit? Or communication between the motor and rear control unit? I'm thinking the former is more likely.Currently the sunroof doesn't work and the system shows a 8010 fault, but when cleared it will work again for some time. Eventually it does not respond any longer, until the fault is cleared again.
