Folks,
Would have that this would have been a well reviewed topic, but after searching a number of different ways both here and the DIY sections, I'm not finding what I am looking for. Last week I noticed my range of distance on my key fob seemed to be getting weaker. I assumed it to the be the battery as I am the original owner of the car (2002) and it has never been replaced. I replaced the battery gently, using a Duracell DL2032 vs OEM panasonic CL2032..which I believe should be compatible? Now the remote does not work. Does the key need to be reprogramed by a technician after replacing the battery? My spare key works fine so the electronics are operating as designed.
Any thoughts?
Thanks in advance!
Also try cleaning both sides of the battery with an ink eraser. I had that problem on two new batteries. Tried both neither worked cleaned one, works fine last two years
