Have a computer-less friend who needs help.....
Does anyone have the procedure of removing the door pocket lids correctly on the 996?
Your help is greatly appreciated... :cheers:
-Eli
eli@pelicanparts.com
Having done this several times, I would recommend an alternative method: get a small torx screwdriver, preferably one with a right angle attachment, and remove the 8 - 10 small screws holding the lid in place. It is very simple, except for the inner-most screw which takes a bit of patience to remove. I have done both sides in less than a half hour.
you know I changed my poly rib belt tonight and it went smooth as silk however I've spent the last :30 minutes trying to put this storage lid on the drivers side door back on and no luck. Can anyone help me with this? Thanks Oh and I've taken off the lid top and I'm just working with the plastic piece. I just can't get the holes to line up.
