Hi everyone
New Member here.
I'm considering adding a duck tail wing on a 997.1S. This involves removing the retractable wing from the decklid and mounting the duck tail on the deck lid. When doing this, the top of the air intake snorkle is clearly showing directly below the duck tail air grill.
It this going to be a problem with water going directly down into the snorkle? I believe there is a hole at the bottom of the airbox to allow for water drainage but I'm not sure and certainly don't want a problem with water accumulation.
Your input is appreciated.
Many thanks.
Edited by 997S.Aero
There is a depression and drainage hole in the bottom of the airbox. You can pour water down that snorkel without any ill effect.
