With help from this forum (thanks Orient Express), I installed the PSE on my 2000 Cab a number of years ago. It was great, worked fine ... but did not last quite the long time I had hoped.
For the past year, it has intermittently not reacted to the Quiet switch. Even though the indicator in the switch would flash as the ignition was turned on, the switch would accomplish nothing. Then, it would began to work again ... maybe for a few weeks ... then back to "no response to the switch. Full time loud. Because I often leave my neighborhood very early, this is not a neighborly situation.
So I pulled the front seat, fuse panel carpet area, back of fuse box and relay carrier and, in effect, rewired the PSE as I checked each connection. Found the ground wire to be suspicious, so thought that might be it ... but couldn't check until I put the seat back as I didn't wish to turn on the airbag warning light.
With all back in place, I turned on the ignition, pressed the switch, and ... voila ... I could hear it operate in the engine compartment, along with seeing the light come on in the switch. Finish buttoning up, start the car, and found I was right back where I started. No response to pressing the switch.
Any ideas? I put a new relay on order with Sunset, but do not hold out much hope since it did operate that one time after my re-wiring.
Sorry I can't be of much help, I've only worked on this system once and it turned out to be a faulty control solenoid.
Just in case anyone suffers similar symptoms ... my new relay arrived and immediately fixed the problem. Of course, now I wish I had tried that before I did what amounted to a re-install of the electrical wiring for the PSE
Was the relay behind the fuse box and where was it located, in other words which is the correct relay? Having similar problem with my '04.
How much was the relay? See my post today on this issue.
The relay is on the relay carrier, forward of and above the fuse panel. Its essentially in the physical middle of the carrier IF, you, like me, did the installation according to factory instructions. If your car came with PSE ... or the factory has changed between your model and mine, that might not be much help.
My relay is part # 996.618.980.03. It is one of the 3 tall relays on my carrier, others are basically cubes. Black with white label with words, "Abgasklappen Relais". ("...klappen' certainly sounds like pigin-German for "noise"). Cost from Sunset was $120 plus shipping.
