Dear all
my passenger side pump started to whine so I done the relay test and it turned out to be the driver side
pump faulty so I bought the two pumps
and replaced them following the diy I also replaced both flanges on top the black one with the filter and
the white one with the regulator
now my car will randomly stall mostly during warm up or some time in stopping light I opened the tank
and rechecked the connection all seem to be fine .also the time I opened it there was a lot of pressure in
both pumps as I can see both hose going to the filter are priming
any suggestion would appreciated ?
with regards
At this point, I wouldnt throw parts at it, but checks will need to be made based on symptoms..
Checking fuel pressure with a mechanical gauge...
Checking fault codes - durametric
Checking for vacuum leaks etc - Smoke Machine
There are many issues that can cause a vehicle to stall and always possible to have more than one specific problem.
but it was running fine before the pump replacment as long as i keep the tank full
i will do ther pressure check and i will test the pumps one by one
and i will take it to local service to get it scanned for codes and i will report here
thank you
hi all
to update both maf replaced pumps were fine whats unusual is before pump replacment it was running fine
thank you all
