I'm replacing my 2001 base model wheel carriers and brakes with the wheel carriers and brakes from an '02 S model.
The plug recepticle for the wheel speed sensor was changed from '01 to '02. The '01 part number notes on Pelican seem to indicate that the '01 part will also work in the '02. Can anyone confirm that?
'02 part number 996-606-407-02-M14
replaced with
"01 part number 996-606-406-00-M14
David
Surprising that nobody responded to this.
A friend with Indie shop checked size and fit. It appears that I can use the '01 sensors in the '02 wheel carriers.
