i noticed at passenger vent side(compartment sensor), the fan behind the sensor, is it allways on? i noticed even when i turned the key of, or leave it next day, the fan is still rotating?
post-84683-0-99526000-1362197593_thumb.j
If it is still running after you've turned the ignition off and removed the key, then your ignition switch is likely suspect. This is a common and well documented issue.
