Probably a silly question, when I turn on the headlight, the buttons including the tiptronic buttons, volume control buttons..etc on the steering wheel keep flashing at 2-4Hz.
is it normal? if not, what wrong with it?
thks !
That's interesting, have you tried turning the steering wheel light buttons on and off again? I've never heard of this fault before.
I tried to turn it off. It does turn the light off, but sometimes it doesn't.
the tiptronic button sometimes responds (70%), but sometimes it doesn't (30%)
Yes, I am asking about whether the dash panel background lighting including the speedo and tachometer background lighting are also flickering.
no flickering in dash panel background lighting
the radio/music control buttons on the driver airbag module including the tiptronic buttons flicker
it can be turned off by pressing the lighting button at the back side, but it does not always work.
called Porsche Services, they said there may be a problem with the small circuit board sitting underneath the airbag.
since the car is working fine, I just leave it to the next services
When I adjust the dimming switch to increase or decrease brightness then all my lights flicker for sometime and then settle down to normal.
Sounds like more of a dirty dimmer switch then anything else.
  • 3 years later...
Hi any resolution with this I have the same lights and buttons flashing now nothing no turn signal wipers or volume for radio
