i'm in a bind - i am throwing codes P1511 and P1517, and in between those, ALL of my cylinder misfires plus P0300. my code description cheat sheet is at work and i am at home...any idea what these are?
very rough idle (if it holds idle at all) and hesitant in the low RPM's. thanks for any help you can give me tonight...
update:
i saw the TB code but that MAF code was also there and i know that little sucker can cause ALL sorts of issues. so, after cleaning the MAF, the MAF harness contacts, the throttle body harness contacts and changing the air filter...it runs fine and dandy, dare i say seemingly smoother than it was. (and i should note that i am a glass-half-empty guy so when I actually think it feels like it's running smoother, it probably is!)
