I bought the car but the center wind deflector that installs behind the seats is not with it. I've been told there are 2 parts, an original equipment one and a "replacement" part, both from Porsche. Is this true, is there a difference, and does anyone know the part numbers? The prices were very different between the two.
  • 10 months later...
CA_BOXSTER
Check to see if you have the attachment clips attached to your roll bars and if so you just need the clear lexan center wind screen. If you don't have the clips you will also need to purchase that kit as well.
Very easy to do. Good DIY PRESS HERE
You can find a used clear center screen in excellent condition on Craigslist or eBay for less than $150.
Porsche Part No. 987-561-621-00
Check current eBay listings by PRESSING HERE
Edited by kbrandsma
