Does anyone know the torque values to attach the diagonal braces to the body when removing the sway bar? Also, does anyone know the three bolts that thread into the body of the car that hold the control arm bracket that also mounts the sway bar to body mounting brackets and the torque values for those bolts? I have to get one of these manuals... TIA.
Sorry.
You need to give us a better description and/or take a picture and indicate which bolts you mean.
Also do you mean the front or the rear or both?
Difficult to say without some pictures.
Here is a link to the front suspension torque settings. Hopefully you'll be able to figure out which is which.
Front Torque Specs
Good Luck,
Graeme
(edit -fixed link - Loren)
I was not able to download the link. I will try to get the picture up, basically it is all of the front bolts that bolt in from underneath to the body. Thanks.
The link should work now...
That was exactly what I needed, thank you for the posting. The diagonal brace and side member torques are the primary ones I needed. Thanks a ton!
