When I lower the top, the passenger window goes down automatically, the drivers does not . It does go down if I click it.
I held both switches in the up position for 10 seconds to calibrate them (from the Bentley book)
Any suggestions?
Jeff
Hold the window button down until the window is all the way down - hold it an additional 10 seconds. Do the same for the window up.
If that does not correct it then you may have a bad window regulator (cable).
