On my 04 cayenne turbo, I put leistung secondary bypass pipes on and everything was going well for past six months but now the drivers side pipe will intermittenly rattle on the frame below. It is attached to all the stock hangers and I was wondering if anyone has experience on how I can perform some adjustments with the pipe so it is not rattling on the subframe anymore.
no experience on a cayenne but its likely one of the mounts has failed or come loose. just get under and take a look, grab it (cold of course) and try shaking it, that should narrow down the problem.
