Hi Guys,i was out sitting in the car with engine running for what must have been about 20-30mins the other day and i noticed my engine temp was higher than normal. It rose and then suddenly fell back to normal and then would go back up and then back to normal. Nowhere near overheating etc. Once up to temp i have never noticed the temp to be anything other than right in the middle. Is this anything to worry about? As soon as i drove off the temp went to the middle, as normal. Thanks in advance.Chris
Thanks for the reply! Only asked because I've never had a car that does this they always remain at the normal! The outside temp was around freezing when it happened!
