I just replaced my n75 valve on my 04 cayenne turbo because I wanted to see if this was causing some of the surging I had noted with WOT. Again my car has an evom tune and diverters. The new n75 valve I put in has smaller hose connnectors than the one that came out of the car and I was wondering if they changed the valve design or did I put the wrong one in. The part numbers matched up. Even if the N75 valve was not working properly or I had a leak in the line due to the larger hoses being connected to the smaller plastic ends on the valve, causing an overboost situation, I would assume that the vehicle would throw an overboost code?
