Suppose the front tires spec remain the same, the rear set changed to 285/35/18. Will this ruin the diff? Or any other close tire alternative with 18" rear wheels?
Is it possible to disengage front diff and drive normally?
Check the Miata tire size calculator, lets you do direct comparisons. http://www.miata.net/garage/tirecalc.html
Its saying the 285/35 is 3.4% smaller so not the same ratio as 295/30. Will it cause problems? Well the rear tires will be smaller than the front if your running the 235/40 so there will be a variance between front and rear. Can the diffs soak up 3.4% change in ratio? Well, many guys go to the 315/25 and it's 3.2% larger and seems to be fine. So i'm guessing yes.
Why not buy the proper size tire or are you getting a deal?
