Hi All,
My car's bettery is pretty new, but one week without driving the car, the battery becomes weak.
When the car (996tt) goes into low-power mode (15 mins after door lock), the current meter at the battery terminal shows 0.81A. Normally, it would be 0.03A, I was told. The after-market bits, like radio/GPS/receiver, have been removed. I've not done other mod to the car. Where can this leak come from?
Thanks.
D.C.
Hi, having read similar questions in the past I believe the thing to do is to connect up your meter in series on your battery and monitor power draw while you one by one pull fuses until you see a drop in the meter. They you should be able to isolate the circuit to focus your attentions on.
