These can be repaired if the potentiometer wire has failed near the end. Strip off a few turns and re-solder. Then reseal the wires onto the board with varnish.
I did a similar repair to a TR3A fuel gauge in 1969.
H
These can be repaired if the potentiometer wire has failed near the end. Strip off a few turns and re-solder. Then reseal the wires onto the board with varnish. I did a similar repair to a TR3A fuel gauge in 1969. H
I can imagine that. An ancient design though and hence the high failure rate. However, I understand a solid state sensor will be $100 more so it's likely cost prohibitive.
