Anyone have experience with the H&R springs? They are supposed to moderately lower the car (1.2-1.3 inches F/R) and improve ride.
They existing in 2 different versions
- 30 mm and - 40 mm
Qualitity is good like almost everything from H+R.
About the comfort of driving it depends on your wheel / tire set up. I am using Eibach springs - 35m with 295/30/22 wheels. The truck has an excellent handling but the comfort is gone. You will feel it if you driving on bad roads. Off road i didnt even think about.
took the plunge and ordered Bilstein HD's and the H&R springs. i'm running 18' turbo wheels, so the modest drop will be welcome. hope to install them this weekend and will report on ride and handling -
And?
and....my coolant pipes went last week! put a damper on my dampers. collected 'kit' for pipes this week and will be tackling that sunday (and rear hatch struts). just as anxious to work on the suspension!
finished coolant pipe job and rear hatch struts. will get to shocks/springs this week and report back on ride/handling...
installed the new shocks and springs. drop in ride height is subtle, but noticeable. initial ride impressions are good. it seems to have eliminated the jouncy/brittleness. i'll post some pics and some more ride impressions at the end of the week. (special thanks to Bart's Motor Works - best german car mechanic in MD!)
Here are the after/before pics which show the subtle drop in ride height. Overall, couldn't be more pleased with the ride. Compliant but well damped. No more stiff-legged feel, and much less up and down ride motions. Would certainly recommend the upgrade or update to any other Cayenne owner with steel springs and regular shocks. :) Install was very straight forward, too.
post-65996-0-95882600-1361925507_thumb.j
post-65996-0-55494800-1361925636_thumb.j
