Hi guys, im new to this forum, i bought my 2000 c2 6spd about two months ago.
I just got my ecu tuned by evoms, which included among other things the turn off of the secondary air injection sistem, after i deleted it and ran for about 100miles i got a p0410 and p1411 bank 1 and 2 below limit,
I talked to evoms and Todd assured me that he turned it off,
Please help, thanks
:welcome:
P0410 Secondary Air Injection System, Bank 1 – Below LimitP1411 Secondary Air Injection System, Bank 2 – Below Limit
- Check to see that your secondary air pump is plugged in.
- Check the fuse (40A fuse next to the DME - under the carpet behind the rear seats)
If it is not either of those it may require a little more work
When i tuned the car i told the tuner to turn off the secondary air system and also the secondary air injection, and when i deleted the hardware for the sai, the codes came up, Is this normal?
Yes, you will always get code(s) now. And if your state has a smog certification the car will fail.
Of course you realize that removing it will have no effect on horsepower (since it was an electric pump).
