Installed a new stereo in the 986 (previously non-bose)...used the recommended harness and had a guy at the stereo shop crimp all the ends for a good solid connection.
All is good except the memory and presets reset every time the car is turned off!
I believe there is a power wire which give continuous power while car is off, can anyone quickly confirm that a '98 Boxster has this wire and what color it is? I assume that either the guy didn't make this connection properly and I just need to pull it out and redo that connection or is it possible the boxster does not have a continuous wire?
As above.
I'm afraid the guy who installed it for you did a poor job. He may have the constant 12v (thick black/red wire) and the 12v switched connected around the wrong way so check for this too.
