02 C2..I have noticed a squeal when you release the clutch in 1st gear. I took the car to my mechanic and he things it is the throw out bearing. I am hearing it in 2nd gear as well now. Is this
a common thing?
As your topic appears to be a DIY question (rather than a DIY Tutorial), we have moved it to the appropriate forum.This is an automatically generated reply. -------------------------------------------------------------
a common thing?
Throw out bearings can and do go bad, but it is not a common failure item. Many times, noises that were thought to be throw out bearings turn out to be from other sources.
