First post...I'm the new owner of a 2004 911 Cab that I bought for my wife.
The LED display on the a/c control was cracked, so I bought a used replacement unit and installed it. The new unit has the temp displayed in Celsius and I can't find any instructions in the manual on how to change it to F. The old unit did display in F.
Anyone know how to do this?
Just found the answer in another post here:
Push the computer control lever (lever below turn signal stalk) forward twice. This should get you into the "set" menu.
Now push the lever down about 5 times until you see the temperature:celsius/fahrenheit function.
Select Celsius and push the lever forward to change. Pull back on the lever several times to back out of the menus
Does anyone know how to do this in a 2001 911 C2, when I push the computer lever forward twice nothing happens?
