Hi all,
I have a 2003 boxster, never missed a beat except ignition replaced about 12months ago.
I went to start today and it cranks but wont start.
I drove it twice today, and was perfect.
I called the NRMA, he came out (real gent) he checked the following and
battery good
fuel pump working (he could hear it)
checked diagnosis and No fault codes
disconnected battery and reconnected (to reset computer)
checked all fuses
He could not work out problem,
the car was on the road and he was unable to check for spark or get to the intake to spray fuel in the intake due to limited access.
Can anyone please suggest what may be the problem, I am very good with cars and will check in daylight tomorrow
I did notice the CRUISE CONTROL Light is always on and will not switch off, before that the cruise control would switch on and off but would not work. could this have anything to do with it???
Cheers, I hope some on may assist
Check the crank position sensor, when they go bad the DME does not see the engine turning over and shuts off the fuel. When it does this, it won't throw a code but the car won't start.
Thank you,
All good now.
Faulty petrol gauge showing quarter full. NO PETROL.
I am thankful it was nothing major.
Thank you again
