Hi all,
Well after I replaced a bad battery and alternator I am still throwing codes. I cleared using my Durametric, drove a few days and tested again. Still having the same codes appear. Any suggestions?
470 CAN comfort in single wire operation. Open circuit, test conditions are not complete. Fault is currently active and is not causing DTC.
907. Load management operation on vehicle sys/dme control module. No additional fault status available, test conditions not completed. Fault is currently active and not causing a DTC
778. Steering angle sensor (no description)
