I would be interested to get some knowledge about this part. Any information is welcome.
Is it a part which is going to fail after some years or some milage?
What happens if its going to fail? Engine stops?
Is it possible to notice when the part is not working proper and how?
Is there always a code when part fails?
Thank you very much!!!
I did some research when i had P0016 code. it seems the sensors are pretty reliable. you need to remove the secondary air pump to access them. it is pretty tight there but not impossible to do.
Cam sensor faults have also been attributed to the vehicles that have extended oil service periods.
Apparently the dirty oil affects the magnitude and rate of motion of the variable cam assembly, which subsequently makes the system log a fault.
It usually starts with a prolonged activation of the starter motor before the engine will running, but a faulty sensor itself should log an error code.
Thank you. Important for me was just to know if a cam sensor fault could end in some way in a stop on the highway and a trip home home by tow away car. Because of the long distances my wife is driving sometime it feels scary. You never know what this time can happen to the big pic
