Where is this located? I have a P0187 Fuel Temperature Sensor B Circuit Intermittent and wanted to check the connections and/or replace the sensor.
Thank you in advance for any info.
Regards,
Jonathan
I use a generic OBDII scanner which gave code P0387 and eventually lead to P0389 if I remember correctly which when refer to the code book show Fuel Temperature Sensor B Circuit Intermittent and Fuel Temperature Sensor B Circuit Faults. Just did coolent pipe change and this start to pop up. Reset but come back every few hundred miles.
Gentlemen, i think there's a misunderstanding here. Cayenne 2004 use an indirect fuel injection (only LOW pressure), Loren's example is a direct fuel injection system (use High and LOW pressure in the same system) with temp. sensor on the low pressure side by the earlier Cayenne DFI. and programmed inside the DME on later Cayenne DFI. I would try with a PIWIS to be sure.
